You’ve been running the whole MSD setup since the early 90’s on two different trucks and four different 454’s - it’s time for something to wear out.
they don't make stuff like they used to
Did you grab that coil wire just to make sure it wasn't loose while it was running?
Only at the coil end, I chose not to ride the lightning of the feed through end.
When do we get to see pics of said truck in said mud?It’s to keep the mud off of us.![]()
I can vouch that it was in mud once.When do we get to see pics of said truck in said mud?
John says that he could/would get his ride out on the trails a whole lot more if one of his partners-in-crime would get off his fatass and put it in gear and finish his own truck build so they could go wheel’n like they both did back in the day - I don’t believe him though, sounds like he is using his buddy as an excuse to me…When do we get to see pics of said truck in said mud?
Or, I could be wrong !
I’d like to reply with reasons for not doing this but since the truck has a 454,TH400/205 already in it all your points are valid - except to say that every time I run a big-block I want more and more of that bodacious torque and the upgrades never end.All this pressure!!
I’m about to have a nice qjet for that 454, just need a battery and some mud tires.
David Freiburger: “don’t get it right, just get it right”
Took this long to get it all washed out of everywhere?I can vouch that it was in mud once.
