That's an interesting point I don't remember the boys from Engine Master's covering. How much actual power is it worth to degree a cam vs going "dot-to-dot"?
Same. I’ve degreed every cam I put in and never saw the need to change it.Not sure I agree with that one, It feel like I'm the redneck that degrees the cam, not the preppy guy.
And that depends on how far off it is how much it matters. Many times its dead on and it wouldn't change a thing, sometimes its off 2 degrees, sometimes 4. I would guess 80% of the time I don't move it because it's as close as it will get. I use 9 keyway sprockets with 2 degree increments.
It shifts the whole curve toward peak power (retarded) or low end torque (advanced).
Many cams are ground with 4 degrees advance built in (the ICL is 4 degrees smaller than the LSA). In those instances when you put it straight up, it should be 4 degrees advanced, if not, you move it until it is.
But if I have one that degrees in at 5 degrees advanced and I could move it to 3, most of the time I would leave it at 5 unless it's a high RPM race setup.
Kinda like explaining Blazer Bash to your co-workers. You went to where and broke your truck? That was fun how?
They don’t get it.
They sorta do, but they don’t go wheeling. Nothing against them, they got go fast toys.Your current coworkers don't get it?
Martin
Rally modeThey sorta do, but they don’t go wheeling. Nothing against them, they got go fast toys.
I'm going from what I've read in performance books over the years and from my Dad who was a GM tech and built budget street engines in the 70s and 80s.The ground in advance is for performance, the vehicle is faster with the advance. If you chain stretches even close 4 degrees that's extremely sloppy, that would be enough to skip a tooth I would guess. Even when I can move the chain 1/4" it's less than a degree of slop, but I would still replace that chain, I don't like any slop of possible, which it is with an old BBC or SBC and a good chain. Although most LS chains are sloppy and then there is the tensioner to prevent chain slap when you let off.
And good true roller chains don't stretch much. Like the ProGear from Avon Gear, better than a Cloyes no doubt.
What timing set were you using? I wonder how much difference a 70k mile fiber gear set would make?Well, I did it so I can put the new chain on. First I measured the chain how much I could move it in the middle, worse than I thought, 7/16"of "flop" in the chain with my finger moving it back and forth. I consider this a lot of slop, out it goes.
Anyway, I degreed it both ways twice because once you have it setup its easy.
It was 110 ICL one way, and 110.75 ICL the other way. I did that twice, same result. The interesting thing was, both times it was off 1 degree on one side of the lobe, and .5 degrees on the other side of the lobe. So the cam lobe is either stretch the chain a little more or a little less depending on whether its going up or down the lobe, interesting. Of course it was only one lifter, but still. So it had .75 degrees of slop at 7/16" of flop. That means if it had ~1.5 degrees or more it would be rubbing on the block or the timing cover. So I feel like the 2 degrees for stretch is a little bit of a myth, but it's plausible, with a very warn chain, that should be replaced a long time ago, and is rubbing on the block.
Also, it was supposed to be 108, so I have to eat my words on not moving a factory crank engine, now I likely will. It was only advanced 2 degrees.
So I will install the new 9 keyway set likely at 2 degrees advanced to try it first and hope it is dead on at 108 ICL, but I'll find out, it will be later this week or early next week.
well......crap!
