lectric80
3/4 ton status
That is just a great looking engine. Subscribed just to see the updates, and I would love to do this someday.
, good luck keeping that thing in the engine compartment
No one noticed the super charger bolted to the side of the the block, good luck keeping that thing in the engine compartment
Thanks. Yeah, I found a #2 aluminum flywheel housing to replace the #1 that I had on it. Here are the pictures. The aluminum one weighs in at just under 50 pounds. The cast iron housing is 150 pounds! Here's another 100 pounds off the engine.stellar effing job of detailing that motor. Didja ever run down an Alum flywheel housing?
Here's inspiration for the dash...Kenworth style.
Here's closer to what I'll actually do for the dash...
Found them on google somewhere. Yeah, I'm planning on doing a one off fiberglass job since my speaker box turned out so well. I figure that in the openings I'll use diamond plate aluminum. I've already kind of speced out where the gauges/stuff will go.Just curious, where did you find these pics and have you seen a completed dash conversion somewhere? Google isn't my best friend today and I can't find any info on this conversion. By the looks of it, it's probably gonna be a one-off fiberglass or carbon fiber job. We all can never have too much dash space for our towrigs though.![]()
