Had planned to spend several hours working on my K5 yesterday, but got too busy with work stuff. I also find that when I go out to work on it I ended up hopping around from one little project to the next, often without completing many of them!
Anyway, my first project was to try and drop my new Mishimoto Radiator in place and get it hooked up. I had read part of @Wolfshark post about his experience, so luckily I did have the right upper radiator hose. Thanks for that part number! What I did not read was the rest of his post about how the Mishimoto doesn't really "drop in place", and you have to make some adjustments to the brackets. You can see from the pic how the upper mount near the radiator cap doesn't clear the fill neck, so I'm going to have to cut that. Plus, the lower mount had to be moved over some to fit properly on the bottom. If this radiator was an inch wider and 3/4" to an inch taller it would probably be a "drop in" situation, but it's going to take some reworking of the brackets to make it work.
Can someone please post a pic of how everything is supposed to be plumbed to the radiator? I can obviously figure out the upper and lower main hoses, but what plumbs into the smaller ports on the side tanks? My buddy had removed my radiator years ago, so I don't have anything to go off for reference on where to plug stuff back in. There appear to be 2 ports on the passenger side that are open (and a 3rd that has a plug on it), and one on the driver's side that has a plug on it.
Also got the axle housing blasted out, and bolted on the disc brake conversion brackets for the disc swap on the 14BFF.
