budget beater - . . . HOLMES 220 single line boom wrecker install starting ..
Makes sense now. Always wanted to take a nice 2wd and swap to 4x4 the way gm did.
Sweet Doubler, shameful to leave it on the shelf when you have a project begging for it.
Nice frame splice, don't think i've ever seen someone turn a crew into a standard cab before. You do good work.
fat butt on the old girl . . . . na just used it to roll it out of the shop for the day .
reason the springs are at 50" center to center is its a dana 70 from a 79 g30 motor home. had 40k miles 4.10 open diff.
end of the road for this old girl today . the time had come to part this out and use the parts to make the budget beater a 4x4 from its 2wd first half of its life .
not using frame / transfer case / exhaust / flatbed / sheet metal . the rest will go in the frame i just made std cab length and then when rolling and loaded it will be covered with the body of the 2wd .
I didn't expect that!!! I didn't know that truck was getting too bad to go on.
look at rear of frame in side shot pic before torn apart . the rear hanger flip bracket is were the factory bump stop would be . few years ago i took 35-40 inch off the back cause it was shot .
now the body is shot in a few key places . she had a newish body put on her around 12 years ago . frame is a 79 k30 c&c truck .
Sure wish that I could have sent you the frame from my old '79 K30 3 years ago, instead of sending it to the crusher. It would have been better to use in a salt country than whatever it got turned into.
taking 33" out of the extra crew cab frame removed the bad spot and got me a clean frame for this now.
so thanks and wish i could stock pile a few frames . but is what it is . if i finish all my trucks i should be good till i cant drive anymore.
and ebay has there discount tire sale again . ends 3/19/18 8am . buy $400 or more and get instant $100 off . can use promo code 2x .
so i just pulled the trigger on 4 of these bad boys . 255/85/16 = 33.30" tall. bfg mud terrain km2 $804.00 shipped to my door.
there going to look SEXY AS HELL on stock rims and hub caps .
...there should be an "adapter" for that.
no problem.
Double chain drive
So you moved shifts and got sick? Allergic to sunlight?
