I've heard good things about those pans
Right,14.5 target your saying right?
how were you losing a cylinder?
Right,
he said I was killing my plugs
I'm using ngk 7052 plugs I think the gap was 35 or 45. Likely 45What gap and heat range are you using?
Not those ****ing champions are they?
Would you guys blow the money on the msd exreme cap and Rotor? It's like 70 vs 30 for the regular one. I have an msd high output coil.
Lol cap and rotor is cheaper.No, in your shoes any money towards a distributor would be for a locked out distributor![]()
I dont even recall there being a harness/plug for that. I'll look into this.Some distributors can be locked out and ran with Fitech. I've seen it done but I chose to use the MSD 85501 drop in distributor that plugs into the FiTech harness. Yes it plugs in, how much easier can it get?
https://www.summitracing.com/parts/msd-85501
you'll need an external coil with this distributor so if that's what you have you can still use that. There's a slight wiring difference with the coil, one quick change on the handheld and you're in business.
