Kind of a newbish question, but how hot is a dana 44 hub supposed to get under normal operation? I put new bearings an axle joints in my both sides of the 72 (first time I've ever done this). It was missing the thrust washer on the inner side of the spindle bearing, bolt that holds the downside of the backing plate, and the little nub on the spindle nut that holds the lockwasher was worn down to almost nothing - all on the passenger side. I was short on time and figured it worked without them before, so would try halfassing that side back togetherr That side was making funny noises(go figure) on the way home and that hub was pretty hot to the touch after the first try, so I got new parts and rebuilt it again. Drove it a few miles and both hubs now are a little warm to the touch, but I figure thats normal. I drive it 50 miles round trip to work a couple times and don't check the hubs, but no kind of smoking or obvious overheat, then yesterday I ran it around town for a bit. Got back home and both sides are hot to the touch. I'm thinking this is normal because the brake rotors are part of the hub and I could see that as being the source of the heat when you're doing a lot of stop and go - am I right or do I need to take it apart again?
