Cylinder heads
I tried finding them elsewhere and haven’t been able to find them. Stupid smog crap lol. I went with painted so I can finally get my truck up and running again.
If you do get them, get the paint off and paint them with very high temperature paint made for stuff like that.
It will not be perfect but it will stay on
Ok cool, I just found the HTC coated ones at classic industries. I’m waiting for them to open so I can call and make sure they have them in stock
@folkenheath is always an option if you need help finding parts. I see you found them but he has sources also.
With painted headers, hang them up so you can heat them up really good with a rosebud tip on a oxy/acetylene torch, then spray them with ATF while they are still good and hot. Then let them cool. That will protect them for a good long while longer than paint, imho.
Can anyone tell me what transfer case I have? I can’t find a tag. The shift pattern is 4-low then shifting down is neutral, 2-high, 4-highIMG_3439.jpegIMG_3438.jpegIMG_3439.jpeg
Anyone know the specific make of that VSS? I've got the exact same one sitting around and can't identify it to look up specs.
My headers are finally coming in next week I also ordered an exhaust pipe kit so I can weld all new exhaust system. I also took out my drive line this weekend and got new u joints. I will be dropping transmission and having that rebuilt and attempt to rebuild my transfer case. Man I’m excited the hole drive train will be brand new.
