Edelbrock Proflo 4
Discussion in 'The Injection Section' started by 6872xtc, Nov 19, 2018.
  1. sweetk30
    sweetk30 5/8 ton status . . . just for BENT77 Premium Member
    Nov 1, 2004
    33,073
    8,357
    horseheads , ny 14845
    Build(s):
    4
    so my pf4 system has been doing good on my truck and i feel i have a solid base tune to start playing with the unit .
    i notice my exhaust if i idle to long gets a hair bit puffy but nothing a few blips of the throttle dont clear up . is this to rich ? seems to smell a bit like it .
    i am 13.8 afr @ idle / 14.0 @ cruise / 12.0 @ full throttle for current settings .
    i did back the cruise down a bit as it was in the mid 13.xx range and this seems to help it not ping hardly at all much any more and i think fuel mileage went up a hair .
    and good tips or tricks to play with guys ?
  2. dyeager535
    28,936
    895
    If you can adjust the timing independently, and your low-load cruise pings now, I'd take the afr back to 14.7:1 under those conditions and reduce timing until it doesn't ping/knock sensor doesn't see any knock.
    You can crutch improper timing by dumping more fuel (or using higher octane fuel) but you dont need to, if you can take fuel and timing out specifically where you dont need the power, which is low-load cruise. It will also increase your mpg under those conditions.
  3. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    5,678
    5,100
    Palisade,Colorado
    Build(s):
    Could it be some condensation in the pipes that you are seeing? But you should be able to lean it out a little more and see if it starts to stumble when you blip the throttle.
    Have you tried leaning out the full throttle AFR to see what happens? And have you done much with the timing?
    Unfortunately this system doesn't use a knock sensor, I assume that is so they don't have problems if someone has a solid lifter valvetrain or a gear drive for the camshaft.
  4. mrk5
    mrk5 The Sticker Guy Moderator GMOTM Winner Author
    Apr 20, 2004
    18,086
    8,553
    Northern Colorado
    Build(s):
    I can just imagine the can of worms a knock sensor would open up on an aftermarket EFI.
    Kain likes this.
  5. Shawn
    Shawn Nuckin Futz! Premium Member GMOTM Winner Author
    2,420
    901
    5280'
    Build(s):
    3
    Anyone else notice Edelbrock updated to 4.0.1:7 on Oct 16?
    I wonder if it fixes the wizard? Looks like they made it now so you can run boost! YES!
    WHAT’S NEW
    Edelbrock’s Pro-Flo 4 EFI system now supports FORCED INDUCTION!
    NEW FEATURES
    Fourth AFR setpoint for boost
    Simple boost timing retard function
    Fourth user-adjustable fueling modifier for boost
    Max boost limiter to protect against overboost
    New forced induction base cals for boosted V8 engines with distributors and Chevy LS engines
    6872xtc, Kain and Bent77 like this.
  6. Bent77
    Bent77 lil meanie Staff Member Moderator GMOTM Winner
    Dec 3, 2002
    26,760
    33,119
    NoCo
    Build(s):
    Game on!
    I definitely will be looking into this
    folkenheath likes this.
  7. mrk5
    Apr 20, 2004
    18,086
    8,553
    Northern Colorado
    Build(s):
    Forced induction plans?
  8. Bent77
    Dec 3, 2002
    26,760
    33,119
    NoCo
    Build(s):
    Would like to
    altitude compensator
    Kain, folkenheath and kgblazerfive like this.
  9. 6872xtc
    Sep 16, 2008
    5,678
    5,100
    Palisade,Colorado
    Build(s):
    I saw that the tablet updated, but hadn't looked into it. Good to know! And I hope that they fixed the problem that I found, which was that I couldn't save a map.
  10. mrk5
    Apr 20, 2004
    18,086
    8,553
    Northern Colorado
    Build(s):
    What about the Citizens Band problem?
    Capt Ron likes this.
  11. 6872xtc
    Sep 16, 2008
    5,678
    5,100
    Palisade,Colorado
    Build(s):
    I keep forgetting to email them...
    Old dude problems... busy with other things too...
    :doah:
    But we tested and if the trucks are parked side by side, the other radio doesn't seem to bother it.
  12. 6872xtc
    Sep 16, 2008
    5,678
    5,100
    Palisade,Colorado
    Build(s):
    Ok, so I went out tonight to install the update in the ECM and see what I may find for any differences.
    DO WHAT I DIDN'T DO!! I read the instructions that showed up when I opened the software on my tablet. I had the stupid idea that I had it in my head, so I went to save and then load the new software. I ended up not saving properly or doing the restore properly, one of the two. I should have made notes. However, it started perfectly and runs fine. I believe that I lost any learning that it did up to this point. My base settings are easy to put in, though.
    I suggest that you open the app before you even go out to the truck, and then make notes of the process.
    I did notice the AFR and timing retard settings that are waiting in the background for boost!!
    Kain likes this.
  13. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    3,893
    2,451
    Glendale, AZ
    Build(s):
    But the question is, have you looked at the CB problem?
    :D
    Kain and mrk5 like this.
  14. mrk5
    Apr 20, 2004
    18,086
    8,553
    Northern Colorado
    Build(s):
    When I saw a new post in this thread, I thought sure that's what it was going to be about.
    JoshHefnerX likes this.
  15. 6872xtc
    Sep 16, 2008
    5,678
    5,100
    Palisade,Colorado
    Build(s):
    NOPE! Still haven't cuz none of you guys showed up to talk to, so why worry?
    JoshHefnerX and Bent77 like this.
  16. mrk5
    Apr 20, 2004
    18,086
    8,553
    Northern Colorado
    Build(s):
    Better look into ham radios. Actually, I wonder if the same problem would happen with those too.
    Kain likes this.
  17. sweetk30
    Nov 1, 2004
    33,073
    8,357
    Build(s):
    4
    We've gotten some results back from what appears to be our first Pro-Flo 4 end user to run a ProCharged 500" Mopar RB motor with the new forced induction update. The guys over at Race Engines Plus in Concord North Carolina put this potent combination together and at just 9 psi of boost, made 880 lbft of torque and 900 hp.
  18. Shawn
    2,420
    901
    5280'
    Build(s):
    3
    Hmm.... Might need to go forced induction but need to address other things first. Talked to Edelbrock at SEMA and they said they didn't have it the 2 bar MAP sensor ready to ship yet but will soon.
    Bent77 likes this.
  19. sweetk30
    Nov 1, 2004
    33,073
    8,357
    Build(s):
    4
    406 sbc dyno run 506 hp / 501 tq
    572 bbc dyno run 714hp / 686 tq
  20. Earldub21
    Earldub21 Registered Member Premium Member
    Apr 9, 2018
    29
    6
    Oak Harbor, WA
    This is from last year, so I am sure you retrieved the bolt that is chilling in behind the AC compressor in the first picture?
    Kain and 6872xtc like this.
