Father-daughter 76 annihilator build
Maiden voyage, first time ever topless, out behind town on way up small hill to watch fireworks, SO COOL:woot:
looks real good, that's a very different camo pattern from what I've seen!
Awesome. Are you going to keep the chrome wheels? With the truck now camo, it looks a little weird :haha: But still, I like the pattern.
why did you get rid of the sidemarker lights? just curious don't they have to be there for street legality?
I did the the top also and just not all finished with it and a lot easier to finish off and on the ground. Zim you miss nothing, the side marker lights had to be moved with the fender flares and I just stuck them aside for now, but I believe your right that they are required. The rims do look out of place with the paint so down the road will hopefully just run some kind of bead locker and Still leaning towards 35 or 37's. Overall it looks close to Vietnam tiger stripe camo that I was trying to mimic, it is a little busy when viewed from certain distances and looks good at other times.:dunno: Definitely different from what I've seen around. I will take more pictures of it out in the real world to see how well it blends.
I have a chance to buy a 79 chevy one ton complete except engine for $ 600. would this work for one ton axle swap and 400 tranny?
flares are still there I believe:dunno:
yep still there. they just need tires that fill them out:waytogo:
One ton axles
Do I need to identify specific axles ie Dana 60 front and 14 bolt ff to do axle swap in the future, or is this one ton I'm going to go look at good to go for a good parts truck to pick up? Any hints as to what to look for or avoid would be appreciated.
k30
went to look at k30, and like many of you were warning I don't think this was as advertised.IMG_9864.JPG
this is the front axle, only ten bolts, 8 lug and truck has a big block in it but it does't look factory. badged k30 and rusted up so not a local truck from around here, probably somewhere in Nevada.
14 bolt rear but not sure ff or not, somebody please chime in with how to tell the difference if you can from pic.
Not really ready to jump to this level yet but just thought I would start watching local crap in paper to see if could get lucky and start collecting parts for the future. Need lots more insight on what is what and how much things are worth before buying but thought I got lucky and now I'm pretty sure this truck was hacked up and this is not originally how a k30 came but it does have 8lug and 14 bolt rear just think it cam with 350 engine and not a dana 60 front axle.
