Yea it's on nowI suggest a larger steering wheel before the first drive.![]()
Sounds bitchenFirst fire sounds roudy
As far as I know, they do.I thought that fel-pro made both thick and thin front section versions of the one piece gasket, maybe my memory is off.
I belive the thicker would be for the post 79 pan with drivers side dip stick from what I could find. I ordered #3001 gasket set from hamburger oil pans. There's a *note that apparently using anything but could cause "irreparable damage to the pan" I don't see how that's even possible but I hope I haven'tI thought that fel-pro made both thick and thin front section versions of the one piece gasket, maybe my memory is off.
Also, afaik, the fel pro one piece has dipstick provisions on both sides.I belive the thicker would be for the post 79 pan with drivers side dip stick from what I could find. I ordered #3001 gasket set from hamburger oil pans. There's a *note that apparently using anything but could cause "irreparable damage to the pan" I don't see how that's even possible but I hope I haven't
I've seen those but the ones I've been getting for the early 010 block are all driver only. Hopefully this 4 pc I have coming and some carefully place "right stuff" should finally remedy this issueAlso, afaik, the fel pro one piece has dipstick provisions on both sides.
