How will my K5/truck look with xx" tires on xx" of lift?
Front
6" tc Springs, 6.5" Long Shackles w/ relocated frame mount, Zero rates to move the axle 1.5" Forward, on a D60.
Rear
DIY F&S, 6" Long Shackles, 4" Lift 56" long TC Springs with Bottom leaf removed, Zero rate to move axle 1.5" Back on a 14FF.
Rolling 39.5" Iroks on 16x10 Rock Crawlers, More trimming needed and bigger tires wanted........It's a sickness!
4" rough country lifrt in front
echobit flit in rear
35s
added 0 rate in front 3/4 rear springs and 37s
38s
this is my 86 longbed (i know its not a k5 but still...) it has about 8 inches of lift rear= 4 in. BDS springs 4in. ORD reverse shackle and taller spring pads
front= 6 in. BDS springs 1in. Hill 4x4 extended shackle 1in. ORD zero rate
its sitting on (temporarially) 38 in. tsl radials
B_to_C's truck
4" TC springs all 4 corners w/1" zero rates in the rear, 35" tires on 15x10 wheels:
4" TC springs all 4 corners w/1" zero rates in the rear, 40" MTR tires on 17x19 wheels:
My truck.
FRONT: 2.5" Superlift springs, REAR: 3" TC springs + 3/4" zero rates; 37" MTRs on 15.8 wheels
...very sweet rigs...here's my '72 K5 when i first bought it...don't have any pics of it on level ground...it was at stock lift with 32" BFG A/Ts...
HERE IT IS WITH A CUSTOM 3" LIFT BY ADDING SPRINGS TO THE PACKS...KINDA DUMB BUT DIDN'T HAVE TOO MUCH MONEY AT THE TIME...THEN SLAPPED ON SOME 35" MTRs ON A 15X8 WHEEL
HERE IT IS ARTICULATING A BIT...THE TIRES WOULD RUB ON THE INNER FENDERS A LITTLE...I DIDN'T RELOCATE THE BUMPSTOPS WHEN I LIFTED IT WHICH IS PROBABLY WHY
IF MY PICS DON'T SHOW UP, PM ME TO FIX THEM
currently redoing my '72...i'm going to run 44" Boggers on H1s, with 52s up front, shackle flip in the rear hopefully i'll get 6" of lift and i'll be tapering the fenders...hopefully those meats clear
4" TC Springs + 0rate up front with 4" blocks in rear. In this pic it's sagging. I'm about 2" higher up front...35" Toyos
3/4 ton stuff chromo shafts,posi front and locked rear 6 inch leafs all around, 35's on 15x10s
PIC 1: 76 1/2 ton Sub. 6" front Tough Contry springs, 2" rear Tough Country springs & 4 inch Offroad Design Shackle Flip. 31" BFG All Terrains on 15" rims.. ....suckuz.
PIC 2: and another side of this hot beast.
PIC 3: 72 K5. Stock suspension.. saggy butt.. I dont like saggy butts in general.. especially not on my Blazer :(
Anyway, 31" Goodyear something or others on 15" Alloy something or other rims.. Man, I really know my crap here.. :rolleyes:
PIC 4: and the 72 again.
the rear is 4" ord shackle flip + 1" zerorates, 56" springs and 12.5 travel shocks.
the front is 4" TC ezrides springs + 1" zerorates and 12.5 travel shocks.
so total is 5" in the rear and 5.75" in the front since the dana60 gives 3/4" of lift.
38x13x16 mounted on 16x8 with 4.25 backspacing.
86 Gmc K3500
12" Superlift Springs (front), 8" Superlift Springs (rear) w/4" blocks, 38.5" Mickey Thompson Baja Claws.
8" bds and zero rated pshed out 1.5" front
5"procomp 64's and home made shackle flip, rear axle back 2" ~9" lift
39.5 iroks
1967 K20
4-inch skyjacker front and rear. 33x12.50x16.5 remington wide brutes. on 16.5x9.75 eagle alloys 4-1/4 backspace. 454/dana60/sm465/14bolt.
the first set of pics is 8" superlifts all the way around with cutouts and 16.5-35/16.5 boggers on 12 inch rims.
the second set is same springs in the front. modified in the rear with a 2.5 shackle flip. 3 inch body lift and 44" grooved Gumbo monster mudders.
71 K5
4" all spring E-Z lift
33x12.5x15's
10" alloy wheels with 4" back spacing
