How will my K5/truck look with xx" tires on xx" of lift?
steve_kibbe
Spartanburg, SC
It's about time to start one.
Rules
1. Post pics on level ground, suspension at ride height
2. If you have a flex shot showing clearences, post if you feel inclined.
3. Any lift is ok, just post what it it (shackle flip, blocks, springs, zero rate, longer shackle...)
4. Post tire/wheel info aswell (wheel width/backspacing if you have it)
5. Members please link your pics from the photo gallery so all can see:D
Ok not a Blazer but same deal. 4in Tuff Country lift, 3in body lift on 35in BFG All Terrains. I could go bigger on the tires, but I don't want to have to get bigger axels.
Before: Stock Wheels and Suspension with 33x12.50
4 inch with 33x12.50s
After: 4 inch lift, 15x10 inch tires with 35x12.50
4" Shakle flip in the back with 2" blocks. 4" springs in the front with long shackles. 35" trxus...
left is all stock on 31s.....right is 4in spring front block rear with 33 mickeys soon to be bfg muds
6" Alcan springs up front, centering pin moved 2" forward, 2" Alcan springs in the rear with a ORD 4" shackle flip, centering pin moved 3" back, sitting on 42x15x15 TSL's.
first pic- Stock suspension. 3 leaf front springs. stock rear springs. 33x1250-15 tires.
Second pic- 6" front lift springs. Rear- 4" block, stock springs with 2" add-a-leaf. 38x1250-15 TSL's. NO TRIM!
Third pic- Same as second only trimmed so no rubbing offroad.
Stats: 4" rancho front springs(well broke in) rear 4" block. 36X12.5R16 TSL Radials on ford rims... This combo requires fender triming. not much but some. at full fles with the tires turned completely srtaight they will not touch the fenders, however if they are turned even slightly they will hit the rear lip of the front fenders. in the fist pic the tires are turned slightly to the right giving a false look at fender to tire clearance but still showing the stance. In the second pic you can see that they are close VERY close. I have not trimed my fenders yet so i rub when i hit driveways and mall entrances. well blah blah blah heres the pics.
Front 2" EZ with 3/4" zero rate 1" longer shackle and ORD 2 1/2" flip rear with 3/4" zero rate.
Good year MT 37x12.50x16.5 on 8 1/4 wide spokes 4 1/2 BS
Both of these pics are with the same 10" lift (Dodge lift springs and custom mounts) one with 38" TSL radails the other with 39.5 Iroks, the trim is to fit the flex. Front axle is 5" forward, rear is 3" back
1989 K5 w/4" ORD Shackle Flip, 1" zero rate, 4" Tuff Country springs
Tuff Country SX8000 shocks
US Wheel Steel Chrome Rims Series 97 / 4.25 backspace
33x12.50x15 Goodyear Wrangler MTR's
If Members link to thier pics in the gallery, everyone can view them here, no need to create another website with 100 percent copied material from CK5.
Top is..... 4" lift with 2" body and overload springs in the rear, sitting on 36"x12.5" swampers on 15" x 10" rims.
Bottom is....... Same lift with no overload springs (saggy but) on 36" x 14.5" PJ Dirt Grips on 16" x 10" wheels
For the STREET I needed to cut the corners off the bottom edges and remove the front mud flaps with the 14.5" tires.
I am gonna do some major trimming here pretty soon so I can play.
Keep in mind width and back spacing play a huge part in if a tire will fit. Just turn your tires and look at the clearances and imagine adding inches to the width. I could get away with taller tires if I got them skinny and mounted them on thin wheels.
