A 2x8 is still small enough for it not to be an issue, right? I plan on dropping in a brand new pump and adding the extra reservoir, but was not sure on the ram.
That will be fine for a trail only rig.
It says that the ports are SAE #6 9/16-18 ORB
I thought that #6 meant 3/8? Don't know what ORB stands for.
Check here for your adaptors
www.discounthydraulichose.com
Does the bore or the rod size affect how responsive the ram is?
This one has the 1.5" bore and a 1" rod diameter
For comparison- Rocklogic and PSC rams and the like have a 1.5" bore and .5 or .75" rods.
i just got done doing mine and i did it really cheap.
grizzly 2x8 ram-54 bucks
fittings-16 bucks
lines and hose-20 bucks
cooler and fan 100 bucks used
i also did the radiator hose on the pump and made my own tabs.best pic i could find.i used all 3/8s lines and hose that way i didnt have to buy adapters for 3/8 s to 1/4 inch.i bought almost everything at agri supply
Sorry ... that item: 9-6645 has been discontinued or is not offered on the web.
Feel free to call 1-800-488-3407, if you would like more assistance.
How are guys attaching the ram on high steer setups?
Martin
TruthThat and praying for no broken knuckles![]()
