I've never removed a top on a K5. I assume it's easy as undoing the bolts along the bottom rail, and around where it seals to the cab. I need to repaint this top now that I've cut holes in it and welded on light tabs. From the looks of it, it should be easy to remove by undoing the bolts along the rail. That would let me blast and paint this top properly. I loosened one of the bolts the other day, and it sort of felt like there must be a square nute or something underneath to anchor the bolt down. Are those nuts loose, but somehow captured so that if I do undue the bolts the nuts won't fall down/off? My concern is being able to get the top bolted back in place since I'm not exactly sure how the previous owner went about attaching it (other than what looks to be the obvious 4 bolts per side on the rail).
