Jimmy rebuild thread
You should post a front end shot
ya know, before and after CO wheeling...
Blew the front gears out getting the Jimmy off of Steel Bender in Moab. Ordered new gears and install kit from Summit Wednesday afternoon. They showed up at 1pm today.
New ring and pinion, gears, seals and ball joints are on the schedule for this weekend.
Been working on the new front housing with a full width truss. All of the link and bypass shock mounts are done. I am rotating the bottom shock mounts 90 degrees because of the articulation. he original design was for go fast with the end links running front to back. I have turned them so there will not be any binding at full stuff and droop. The problem is, the front shock bolts will hit the tie rod and drop about 30 percent of my steering. That is no Bueno. So I looked into raising the bottom of the shock 1.5 inches. With that, the shocks will bottom out on up stroke. I loose that total in stroke.
Not sure where to go from here.
Rotate the shock mounts back to previous location and use spacers to allow for articulation?
Can you change the upper mount to match the 1.5" change at the other end?
Need more pics.
Walked away and fixed my blasting cabinet with new nozzle and seals.
Went back and started over with measuring and full scale layout.
The tie rod has been hitting the shock bracket since I originally built the truck. Limited the right turn radius by a small amount. Taking each measurement and transferring it to graph paper old school helped. I was trying to go straight to cardboard for templates. I was measuring from the axle tube with a small square. Turns out, a small plumb-bob works better for getting it fine tuned. I know it should work and I should have more clearance. Yep. I was laying the shock diameter out from the axle tube, not the truss. I have another 1/4" of clearance to the tie rod now.
Some times, you have to walk away and start over to see the big picture to make the fine details work.
Sometimes I use my sign design program like that. Especially helps with figuring out angles and lengths.
All these fancy things to fix stuff, and pad and paper still yields results. Well, and Wades sliderule
Sound pretty much guarantee the shocks will unload when the nose goes up
I like it, would like to build a truss on my axle. Other then clearance any issue going below the axle tube? I believe going on top as you force down it would put pressure going up?
