She me more pics from last night
All welded...
But I warped it and it has a reverse oil can..
Doesn't really show, but Im in the process of fixing it.
And, I did a good job on hammering out the small dent that was hiding in the trim.
Last night I drilled a hole saw through the inside of the rear door, and put a harmonic balancer puller inside, with the bolt sticking out.
Put a 3" square 3/16" plate inside behind the oil can center. And put pressure on it pushing it out even.
Maybe a tab proud.
Then took the bottle torch to the area to warm it up.
And let it cool on its own.
The oil can effect is way less, and it will stay out for the most part. But there's one area right at the seem that needs further persuasion.
But I was too late to be hammering so that's what I'm starting with today.
Then I'll get the inner in, bondo the outside, and throw a skim coat on the new side door.
Hopefully having them primed today and the other tail door started.
