I need to double check but I think this is what I use on my diesel suburban.It was under this when it was a diesel.
Dude gave me a box of 9 of those filters.
I still have 7-8 of em.
May do something like that. Not sure yet.I need to double check but I think this is what I use on my diesel suburban.
If so I will take them off your hands
Gasoline is thinner than diesel, or engine oil. If in fact you do go to 1/2 id fuel lines your pressure will go down. Uping the return might help if the regulator has adequate size.Really, I have no idea
They're pretty much the same as an oil filter and oil systems have higher pressures than 60 psi. I just always figured it was sketchy with a spin on oil filter looking thing running 60 psi of gas.
Fuel filters are Fuel resistant.I was kind of more worried about gas eating the internals of it, or the rubber gasket on top breaking down.
Summit has a few nice ones with -6AN in/out that I think I'll run in this.
I also found a great and easy spot to put the spin on one in my skid loader.
It's not that simple, they have different grades of materials that are resistant to different fuels for a reason. They have to go through a elaborate distillation/separation process to get the different fuels out of the crude. They may come from the same source but petroleum jelly is not kerosene, as diesel fuel is not gasoline. Start adding in 10% or more ethanol like they do in gasoline then you really have an issue with material breakdown.Fuel filters are Fuel resistant.
They all come from the same crude oil so they all have the same characteristics.
I over simplified my answer.It's not that simple, they have different grades of materials that are resistant to different fuels for a reason. They have to go through a elaborate distillation/separation process to get the different fuels out of the crude. They may come from the same source but petroleum jelly is not kerosene, as diesel fuel is not gasoline. Start adding in 10% or more ethanol like they do in gasoline then you really have an issue with material breakdown.
You may get away with it under certain circumstances but I certainly wouldn't recommend it.
