What I've been doing to find belts is exactly that, but when I hit the one I have I started running into issues finding the next one up.
With the way it seems to stretch when I gun it, I think a longer one would be a bad thing. That'd jump even more probably.
I'm actually thinking decel is when most of the problem happens. Decel had to be the only way it cranked the tensioner down so far that it got caught like it did the other day.
That or something to do with the power steering pump being under load trying to power brake.
May need to do some GoPro under the hood vids.
It's got the AC Delco professional with relatively low miles. Think it's bad already from the way I drove it, or my setup?
The alts I got say they're ok at high RPM. And like mentioned, it ran all year last year throwing the belt once, leaving the same intersection the same direction.
At that intersection I'm turning left, smash it hard, hold it long enough to let it shift, then lift all the way to back down cause I'm in town.
It's actually the same corner I did the under car vid on.
