LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
Not sure if this does.
But I know it's commanding or reading weird chit one way or the other
The setups I'm used to use a stepper motor to drive the IAC pintle, so the count is what's commanded/expected. I've never seen one with feedback that tells you the actual position.
Luke is correct, a datalog will tell you what the IAC is supposed to do, but not what it actually does. The IAC doesn't have that capability to give relative position to the ECU for recording.
Now, if the datalog is saying its doing funny things, that could still be an indication of a problem. But if the IAC is faulty and the engine is stalling its probably going to say its opening when in reality it may not be.
Yeah. It likes the new converter :thumb:
:burnout:
This took about 1 second to spin em to 6000r's,
Then let it creep forward a half second or so, let off the brake entirely and let her eat.:woot:IMG_20260820_060635836_MP.jpg
As for the starting thing. It hasn't done it in a while now, rainy days or not :dunno:
Overall...... I'm currently happy as F**k with it :thumb:
The ability to do rolling burnouts would be awesome, but when you juice up a pig, you can only expect so much. :haha:
Getting REAL close to swapping rear tires finally.
Next set is one size skinnier, but .75" taller. So probably about the same .
Eventually, I'll get to putting wheels identical to these back on it. (Probably without the rings, or thinner ones). So i can go down to 245's.
Then we'll get some LONG posi marks lol.
Your description isn't clear on the tire sizes.
Can you post the 2 sizes?
Currently on the truck
Front 275/45/20. 29.8" tall. 10.8" section width.
Rear. 285/50/20. 31.3. 11.7
These are the same make/model lol.
Next up I have 2 options.
Probably taking option 1.... But
Opt. 1
Just change rears to 275/55/20. 31.9". 11.2"
Opt. 2
Swap current fronts to the rear, and put
255/45/20s on front. 29.1". 10"
When I go to the 16"s for fun, it'll be 245/75/16
30.5". 9.8" :whistle: IMG_20260820_155723037_MP.jpg
View attachment 533497View attachment 533498
Opt. 1
Opt. 2
30.5". 9.8" :whistle: View attachment 533499
Ok so different height but close enough.
You said about the same i thought you thought they are the same.
By the way .75" taller means .375" higher because it's half the diameter difference.
You might get more height from the new tread than difference in size
I was thinking the skinnier gives a better chance of breaking them free, but the newer tread, and taller tire, makes for a little less final drive, so figured the difference in burnout ability would be an un-noticable wash.
It'll be better when I go to smaller diameter AND skinnier lol.
Ok..
The current front and back are both Yokohama geolander... But the fronts are X-CV
And the rears are H/T
The current fronts were bought as rears, and the 255/45s were bought as the fronts.
Those match.
First car show I'll have ever entered.
Tomorrow morning. :thumb:
Don't care if a single person votes for my chit.
Just want to put it in there because regardless of what anyone else thinks of it....
I'M FUGGIN PROUD OF IT!
I can stand back, look at it and say "I DID THAT!"
Interior, chit as it is, and minor paint flaws I've found..... Fug it. It's came a LONG ways, and if I finished it all at once, what the ell else would I have to do.... ?
Work on the house? It keeps me warm n dry, so fug that too lol.
Celebratory moment... So beer and Jack Bonded :waytogo: IMG_20260821_141550151_HDR.jpg
I just wiped down the interior....
And Im pretty sure it's the first time I've done it in the 6 years I've owned it lol.
Odd question....
Something I've been kicking around.
The instructions for this engine said to prime it with mobil 1 15w-50 prior to starting.
So basically breaking it in on serious synthetic.
But, to this date, about 2000 miles in, it still seems like the rings haven't set.
It clearly burns oil, and has blow by.
Would it hurt anything you think, if I ran a change of regular dino juice through it ?
Not taking it to the drag track or anything like that.
But just change it and drive it normally for a while.
1000 miles or something?
Just not sure how it's going to seat, and wondered if the oil burning is causing me any issues.
Idle, O2 sensor reading, etc... :dunno:
I can smell it in the exhaust, and it routinely pushes the dipstick out of the tube 1/2-3/4"
