Fred_M1010
Now the winch-mount is done
The lower braces got a little warped when I welded them.
So I cut them up again and tightened down all the bolts before welding it together again.
It's really important the surfaces where the bolts go are flat against each other, .
I also cut 1" along the whole length of them, both to save some weight and some groundclearance.
They are by far strong enough anyway.
Temporary mounting of the control-box
This will probably be a permanent solution
Some more random pics:
The angle-iron I've used is about 2 3/8 x 2 3/8 and 9/32" thick.
If I would do it again I would move it about an inch further back and a half inch up.
Then It would be completely hidden behind the bumper, now I'll have to cut some in the lower section of the bumper.
Next step is rewiring the rear lights.
Not something I look forward to
