dirtygoat
Nice build...
I would love to have one that's original... It would make a great tow/camping rig...
Just for experimental sake, try jacking the front of the truck up on the tie rod and watch how much it gives. You wont get the front tires off the ground. Not that this is a true test, but you will see how soft the steel is that is made of. Once it bends, good luck getting it back straight again.
If i remember correctly only the tre's are solid.
Stocker is just not gonna handle the 42's.
I meant for stock trucks. That only seems to show crossover stuff.
I even had the mounting-bracket for the tank already on my engine...?
I used a pieace of an old radiator hose between the adapter and the oil-pump
http://forumbilder.se
Does anyone now what years they used the external tank.
I'm thinking I might have had one originally, since I had the bracket for it.
Very cool pics! As I was scrolling down through the pictures, I was wondering if the draglink was holding up. I guess not.
I think it is time to start over on the draglink.
I though all hydroboost trucks had the extra p/s fluid reservoir? My '90 K5 with the factory 6.2 has that reservoir, and the pump simply has a hose nipple on the top that the rubber hose attaches to with a hose clamp (i.e. no crazy adaptor needed).
I think my brake-discs needs some lubricationErrrrrrrk errrrrrrrk errrrrrrrrrk...
