Before I bought a 20ton press, yesAnyone ever used a ball joint press to remove leaf spring bushings? Lol
just saying, push the axle back now and save money in the long runRun the 56s backwards. Do it now before you need a new driveshaft and shock mounts. You’re probably in for a new tailpipe anyway. Do it now DO IT NOOWWWW!!
56" backwards = 4" push back of the axle .
the m1009 white blazer i built for std setup but 1" setback via new spring perches cause we went from a k30 truck axle to a 1/2 ton blazer combo . the 1" push back centered the axle real nice .
if your going to do crazy flex then maybe yes push back . but d.d and trails i would say the 1"-1.5" back is a good compromise .
That’s a sweet truck man!! I want a grill like yours. I thought about putting a led bar in between the center chrome bars in that style grill....not sure if anyone has done that yetI run 6+overload 56's in the rear and 6 leaf 52's up front...
Plenty of flex and rides good.
