The primer and paint I used is rattle can Krylon.
Got the fuse/relay box installed and modified the engine wire harness.
I'll get some pics tomorrow, too dark now.
Gotta chop the front of the bed and get it mounted so I can get the fuel cells mounted and run the fuel system.
Thanks guys.
I reworked the 6.0s wire harness, routed it towards the pass side battery tray and started mounting the fuse/relay panel and PCM (once it gets back from tuning)
Ok. Changed my mind on the fuse relay panel I made. Couldnt figure out how to weatherproof it. So looked around the scrap yard and scored an underhood fuse relay box from a 96 Camaro. Compact and weatherproof.
