Old faithful
I think with this proof of poor assembly as evidence I'll be clear of them blaming the installing party or the EFI
Don't take what I said as me thinking you caused this. I've got a better understanding of how dealers operate than most because of what I do. I don't doubt that your engine had some issues that you clearly pointed out. I'm just trying to give you help to get this resolved.
How about a quick timeline here. Purchase, install, when you found the first issue with the valve keeper and rear main seal to now. Is there a reason you didn't take it back to the dealer that did the work to fix GM's first two major blunders? I totally get you may have moved with your military service and again, it's not your fault if you did move.
Keep this in mind about certain dealers. As in one you didn't deal with originally. If the issue looks to be a pain in the ass and they didn't sell it to you, they won't mess with it. Not defending them, but dealers tend to take the path of least resistance if they didn't originally sell anything to you. It doesn't bother me, but it does bring an added degree of difficulty for sure. This is all the more reason to figure out the problem yourself prior to handing it off to a dealer most likely unwilling to go through the effort if they don't have it handed to them. For example, we sold a GM performance crate and the customer lived a couple of hours away. He experienced an issue with the oil pump making noise and took it out and went to a dealer close by. Even though they could have helped they told him to go back to the dealer that sold it to him. Hell, all they had to do was give him a stinking oil pump. Nope. He called me back, I ordered a pump and took it up myself for him.
Just like you did before, you have to do your homework. Get to the root cause. Prove what is going wrong. Know what the problem is so they can't pull any crap on you.
It looks like you have the coolant temp sensor in the thermostat housing. Am I correct on this? If you have a working thermostat, the sensor won't read as accurately as it would in the intake manifold. Once the thermostat opens, it should be fine, it's only when warming up and there isn't coolant flowing that it will not give the proper readings. And the PF4 makes adjustments based partially on the engine temperature.
Not sure if you already know this or if I am mistaken about what I am seeing.
Good eye but actually that's just the reading that goes to the stock temp gauge so it doesn't just sit there all useless an I can drive without my tablet for the PF4 the actual temp gauge for the PF4 is installed into the intake manifold where they directed it to be.
Yeah I've wanted to do that for years. Might be time
Probably have to get the vice grips on it, which will likely ruin it
Same specs ad the previous motor or they change it up a bit.
Still looks awesome in that engine bay
Now get some miles on it an enjoy the ride
Stillnlools awesome in that engine bay
Thanks man and its same specs 4 bolt mains and all that. This time it says "hi perf" on the block tho. Probably doesn't mean anything significant. Almost ready for that first oil change after brake in!
The "HI PERF" stamp equals to about an .00002 hp but like chrome valve covers do
But non the lease congrats again
It's almost like xmas
An yes some assembly is required
An Happy Early birthday Marine
Haha chrome valve covers an stickers add all that easy HP. Thanks! An Happy early birthday to yourself Marine!
Every crate engine 454 I have seen had that on.
Not sure if they all are
Roller lifter or flat tappet?
10w30 for either but if it is a flat tappet lifter setup I'd be using oil with high zinc content for sure. If not you'll be putting a cam and lifters in sooner than you would like.
