After two weeks of the flu, I'm finally back to normal hours in the shop. It sucks working when you're sick, only made worse when there are projects still to deliver. My next client project is still a few weeks off, so I'm I'm using that time for the suburban in advance of trips to Katemcy, Colorado, and Moab.
Glow plugs - 8 new 60G plugs cured the hard starting, which should be no surprise since 3 were dead (no conductivity), 2 were marginal, and only 3 were working correctly. 12 years isn't bad for a set of Kennedy quick heats, but I went back to Delcos since I'll likely end up with supplemental manual control. Also, I always feel smarter than I actual am when things come apart easily because I used anti-seize all those years earlier.
Back in with new anti-seize. I should feel smart in another decade or so.
Next, my magnum case continues to burp fluid. I can't seem to get the fill level right, so I have a highly technical solution. As with most of my temporary solutions, I'll probably use this for a while.
While waiting on my order from Ruffstuff, I swapped mufflers with my dad. He wanted the 30" quiet tone and I wanted the 18" resonator. More turbo noises; same drone. Dynapad is on order.
Since the intercooler, I haven't had horns. Now I do, and they sound like a German clown car. I've since swapped for the 400hz and 500hz combo, which is distinctly more American.
On to suspension details, I have a sagging rear spring, and in talking with
@Stephen, I've swapped my springs side to side and will soon build extended bump stops. To avoid additional sagging, the upper limit of travel will need to be when the springs are just about flat.
In the same department, I've started building double shear shock mounts for the now significantly stiffer Bilsteins. I started with the driver rear.
I did the lower mounts some time back.
There, all caught up, no more flu, great weather days ahead, and lots more to do.
David
