Is it in yet?
There’s a lot to do for first fire, but we’re close.
You’re telegraphing my moves. Running it without an intake makes checking fuel leaks really easy.Oddly enough, intake manifold isn't strictly required for this...
David
First fire: April 2, 2022, 2:19PM Texas Standard Time.
David
And?…First fire: April 2, 2022, 2:19PM Texas Standard Time.
David
For sure. I was just looking for confirmation that everything was green light from the first fire.There’s a ton of reassembly to do. Then, get a few heat cycles on it, break in the rings, drive it, change the oil, load it on a trailer, drive to Moab, and crash EJS.
David
So far, green across the board. We ran it for about a minute, but with no coolant, we had to move on pretty quickly to buttoning things up and getting water in the block. There’s still some air to purge, and I think we’re running in maybe 6-1/2 cylinders right now.For sure. I was just looking for confirmation that everything was green light from the first fire.
Great to hear. I know I’m always nervous as a stray cat when I fire up a new build!So far, green across the board. We ran it for about a minute, but with no coolant, we had to move on pretty quickly to buttoning things up and getting water in the block. There’s still some air to purge, and I think we’re running in maybe 6-1/2 cylinders right now.
But, we’re leak-free and moving on to all the bolt on stuff, and there’s a bunch of it.
David
It’s definitely a weight lifted. Looking forward to seating the rings with a few throttle ups.Great to hear. I know I’m always nervous as a stray cat when I fire up a new build!
