That’s a terrifying problem. This combo is good for up to 45ish psi, and I’ll make use of up to 25-30 of that. I haven’t heard of folks blowing up their 351s, which is kind of an upgraded HX40 anyway.It's been a minute but do the HE351's have a better shaft than the HX40's? I remember those having a bad habit of grenading themselves much over 20-25psi.
It would be good if the upgrades included the shaft.
David
Go big. If anybody can do it, he is the one. Though I'd like to be around if somebody pushed that kind of boost to a stock 6.5 just so I can see the carnage when it remodels the block with some new windows.30PSI on a 6.5?
Interesting.
Those M12 head studs need to earn their keep.30PSI on a 6.5?
Roger, and in stages. The pump is at 250hp/500lb-ft right now, and the wastegae pops dead on at 12 just as the turbo is getting into the meaty part of its efficiency bubble. I’ll see what this fuel level supports and needs, and go up from there. Right now, there is absolutely zero black smoke.Go big.
David
Preach. It’s hard not to wonder the same when black smoke is $5 a gallon.I wonder how much power they leave on the table and money wasted at fuel prices north of 5 bucks a gallon right now.
It's Dakota Digital, and the install is cataloged back here. I got them to adjust the tach down to 4K, but otherwise it's the standard early style VHX setup.Who's gauge setup did you end up with?
The 833-6284 party pump.I don’t remember if you posted the Injection pump number you are using?
David
I’m really curious to see what it does. It’ll bark the 40s at 3/4 throttle, and that’s still at the 250hp tune. 1/8 or a 1/4 turn of the fuel screw could make it interesting.Where is the video of the burning rubber?
I've thought about using those in some places too. Seems like they could be handy to have.I’m going full tacticool and making new barn door inner skins with MOLLE panels.
Figured it’ll be a good spot to store first aid, straps, and other odds and ends that usually find their way into rolling around the back of the truck.
My factory trim panels pretty much disintegrated, pressing me to come up with something else.
David
Mmmmm tire barks, my Greg trans does the same! On concrete it’s wild and I can feel the tires shake.I’m really curious to see what it does. It’ll bark the 40s at 3/4 throttle, and that’s still at the 250hp tune. 1/8 or a 1/4 turn of the fuel screw could make it interesting.
David
