Of course, now I am so down in my back that I cant get around or sleep at night. 2 spinal fusions and my hobbies r building race boats and monster 4x4's. I am an idiot and this is a sickness.....problem is....I have had it all my life!!!
The problem with this one is that with about 130 rear wheel hp.....it won't do it unless I pour clorox on the floor. That will get solved soon enough. The engine and tranny is next!! I gotta take some time and let my back heal up and then the motor is coming out. I am very happy with the way it has turned out. I did 100% of it by myself (except the driveshafts). Thanks again for all the compliments from you guys and motivation to keep rolling through it.whats your plan for under the hood??
Well, I took my first drive today and drove FREAKIN AWESOME!!!! Breaks kick aZZ. Steering is tight. Transfer case is so quite u cant tell that it is in there. Got the steering wheel centered. Toe is out about 1/4". Thats tomorrow. I got my new bearings installed on the front Power Lok with some good ole boy redneck engineering. I ended up using a front crank gear for a Jesel belt drive for a BBC. It fit like a glove for use as a Race Driver!
Just have to ask why you didn't do the power lock before the axle was put under the burb?
I got carried away with myself on the install...I got tunnel vision to keep rollin....![]()
Been there before. Sure would have been easier on the back then having to climb under there to do it now.
THUNDERUSONE I would like to chassis dyno it just to see if it will break a 100hp.[/quote said:
If you're going to upgrade to a new BIG, high horsepower engine... why not swamp in a Cummins? You could easily get a 97' 12 valve built to the hilt for the money you're talking about (just would be my preference).
