Project MULE - Expedition build on a 1991 1500 4x4 Suburban
Hood Louvers going in.
Anyone know if I can mountt he manual mirrors in the place of the 90-91 power mirror mount?
No. You cant. Its alot different. Unless you REALLY wanted to. I know you have the skills to make it happen, but it would require fab.
You can see in this pic where the other style mounts,
The mirrors. I guess I don't understand the vents either. Are you going to weld them in, or rivet them on?
Martin
On the mirrors,
I personally dont like how high and close these electric 90-91 mirrors are. For me they feel like they are blocking some of the view. I think the manual ones are personally better plus you have more mirror to look at at.
On the vents,
the vents will help keep the engine bay cooler and keep the engine from overheating. This is nothing new, I did them on my Cherokee and there is not even enough room for a mouse under a Cherokee hood. After I did that I could sit in traffic or on the trail with he A/C on and never overheat and that's in the Arizona summer. A cooler engine is a happier engine.
They are designed to be riveted in but I will be painting the hood and the vents and the rivets are powdercoated white to match the vents so I will use SS hardware instead.
Well the body is off for paint and I am here wet-sanding the hood.:woot:NOT!
After that I have the Moon visor, grille, gutters, side mirrors and vents to sand. Oh...joy:eek1:
You should have tried to swap someone complete doors before you sent it off for paint.
Martin
I want to do good louvers while mine is all apart. Where did you get those?
I got these in a trade but they are the XL size from hoodlouvers.com. I had actually ordered these and were in mid shipment when I got these in trade. So I sent those back.
