There was some rust in the footwell area and cab support right above where the torsion box was rusted.
He has 30 years experience and does the work in my garage.Some solid sheet metal work there! You were lucky to find a guy, most body guys hate rust repair work and do whatever they can to avoid doing it...
Rust repair is kind of his thing. http://www.progressiverestorations.com
I did get them off without removing the fender but can tell it will be a bitch to get them back on especially the upper ones.Getting them off was easy enough. Putting them back on without cross threading is the challenge!
Offset box end wrench made it easier to get off as well.
The secret seems to be to start the lower single bolt first as that helps position the plate behind the A pillar (plate with all 3 threaded holes in it) and then slide the inner most top bolt in the hole of the hinge. From that point its just using the inner finger from each hand, one on the top and one on the bottom of the bolt to turn it an 1/8th of a turn at a time until it starts to catch the threads. I will take some pics when I do the drivers side.If you still have all your knuckles, six times is damn good. To get to those inner bolts you need flat fingers with like eight joints.
-- A
Not too late for the driver side!I guess now it's too late to mention a trash can and 2x4 holdup a lifted trucks door nicely
