bp71k5
3/4 ton status
Yep, what he said. There’s a clamp holding the column up. If you loosen the bolts to drip that clamp, the column will lower enough to remove the bezel.Yep seems I had to lower mine to get the bezel to come out, should just be 2 bolts
