The Camaro steering wheel is going by by at some point.
Thanks @tRustyK5 this is the wheel (style) that I am going with, don't think that's the one you have though?If you want stock I have a Black first gen wheel here. It's the only first gen part I have...and could be yours for nothing.
Always nice to have a good stock wheel as a back-up at the very least.
PM inbound!
The main attraction is that the avoids a COMMON problem found in most aftermarket wheels. The 3-spoke design and placement won't block the view of the gauges. SO many steering wheels (4-spoke and even some 3-spoke) designs put the spokes in the upper hemisphere of the wheel, so your sightlines to the speedometer and fuel gauge are constantly blocked and you end up moving your head from side to side until you can finally catch a glimpse of the gauge. It's also around 14" - 14.5" diameter which gets rid of a lot of that "school bus" vibe, gives you a quicker turning ratio and makes it a little easier to climb into the truck without smacking your legs on the wheel.
Those are like 8" in diameter, I hear it makes it real easy to drive in hand cuffs. LOL
Can we name this build yet?
I'm in for "The Onion Build". lol![]()
