Guy down the road has a set of pro comps with 4.5 backspacing -15mm offset . Just need to know if these will work.
Mine are 4.5" but aren't inside the fenders. But I don't think that they hang out too far.So.... what back spacing am I looking for to keep the wheels inside the fenders? 4.5? 5.5?
I think 5.5" would be too much.So.... what back spacing am I looking for to keep the wheels inside the fenders? 4.5? 5.5?
Also, mine is 12.5" from the top of the axle tube on the D60 to the bottom of the factory bump stop bracket on the frame. I have a 1" body lift separating the '79 frame from the '90 body. And 57.75" to the bottom of the driver side door handle. (Chrome rib) just to give you an idea how tall mine is.
Just cut more. Cheaper than springs and drive shafts
Now that you have it, can you check if the wheel was 5" if it would clear the steering arm, tie rod etc...Definitely drives way better with the 37’s wow the difference is pretty incredible actually.
The ones you put on, how much clearance is there between the wheels and the steering components?The wheels I took off? These ones are 4.25
Quite a bit. They actually stick out of the fenders more than the last set by quite a bit. Doesn’t look like they’ll even get close to the tie rods.The ones you put on, how much clearance is there between the wheels and the steering components?
No more taillights for you from this engineer...Engineers. Boo hiss
