NEK5
3/4 ton status
sorry, timing is just something I've NEVER had to deal with. Please bare with my lack of knowledgeWhat the?....just adjust your timing to show 10 deg before TDC ie initial advance, and have your dizzy re-curved to have 9 deg (1 deg on dizzy = 2 at crank) come on full by 2250-2500rpm. Full advance will then be approx 28 deg (10 initial + 9x2 at dizzy). You may have to play around with lighter springs to achieve this, you'll only have to pull your dizzy if you get a shop to play with the curve for you.
Jas
