Thank you. That is what I have been looking for.
I am going to run a switch on the shifter for the TCC. It will also be fed through a switch on the brake pedal. If the brake is pushed, it unlocks. Just in case my old brain forgets. Will also have a switch on the base of the shifter that it will only lock up in OD. Basically 2 safeties to keep me from shifting with it locked or while stopped.
