ReTonkulous
Utlilmaster P30
Did your kit come with compressor, and engine brackets?
I got the site to work on my PC, slow but got to pick make and model and see offerings.
I was looking for my early Bronco, $2200+. I am not sure what I would be getting. It shows the under dash kit, scroll down and I see a condenser kit, is that included or extra?
Neither kit shows compressor or brackets.
I got everything but the compressor and engine brackets. I have to custom mount it do to the cab over design of the truck.
It was just under $1600 for the biggest one. Compressor and adapter were $400 for what I needed.
Added the good stuff. 55psi cold still. Maybe a tiny bit more. At 185*, at idle, it now has a tick over 20psi.
You know when I first read that, I thought you meant there was a ticking noise like a lifter.
The fan was making a ticking noise because it was rubbing something. Found it.
It took 2 hours to get that out. There was a hidden river in a non accessible area. Had to have been put in before another panel was added. I hate prying stuff apart.
I needed to pull the existing temp sending unit so I can cover that hole.
Now I have been watching the temp gauge go to 180 or so. Then it would drop a lot, then come back. It is a mechanical unit. I follow the line to the engine. The sending unit is laying on the exhaust manifold. Not even in the water passages anywhere. Fooled me.
nothing wrong with a nap at lvl 59
That last picture reminds me so much of my non retirement days
I was thinking you should just about have all the room in the world for it.
