EFI does everything it can to start and stay running... carbs do the exact opposite..
Now that has me thinking...
COMPLETE TURNKEY ENGINES
generally 80 -120k miles - Sometimes less at a premium price!
4.8L ---------------------- starting at $1995.00
5.3L LM7 ------------------ starting at $2400.00
5.3L LM7 w/ Z06 Cam ------ starting at $3100.00
6.0L LQ4 ------------------- starting at $3200.00
6.0L LQ4 w/Z06 Cam ------- starting at $3900.00
6.0L LQ9 ------------------- starting at $4200.00
The prices above are somewhat the average for engines lately, for the real nice, clean, decent mileage stuff.
INVENTORY TO PROCESS
as of September 24, 2012
Sorry about increased prices. Wrecking yard prices are up 20-40%
from a year ago on the good clean stuff and especially on the 6.0L's.
Here is some true BUDGET V8 power for you in the 4.8L.
Same iron block as the 5.3 with aluminum heads.
They look identical and are actually hard to tell apart from the outside.
2001 4.8L, 76k miles - $1995.00 Turnkey
This is a pretty clean California based engine with low miles. Only 10 less HP than a 5.3! I believe with my performance tune the 4.8L should be around 305-310HP. Only a TH350/400, 700R4, Manual, etc. can be used with this engine. The original trans pigtail has already been cut. DBC throttle body.
2002 4.8L, 116k miles - $1995.00 Turnkey + Options!
Another clean California based engine. Only 10 less HP than a 5.3! I believe with my performance tune the 4.8L should be around 305-310HP. The 4L60e, TH350/400, 700R4, Manual, etc. transmissions can be used with this one. DBC throttle body.
Here are some famous 5.3L's
2004 5.3L, 88k miles - $2600.00 Turnkey + Options!
Typical 5.3 that everyone likes and is looking for. This one is a real nice and clean 100% California, Bay Area motor. The Z06 cam & valve spring option for +$700 makes this engine put out right around 360HP. Can run Th350/400, Manual or the factory matted 4L60e. Cruise control is also available on this one.
Here is a standard MONSTER 6.0L'S
2002 6.0L LQ4, 106k miles - $3600.00 Turnkey + Options!
Another clean California based engine. This LQ4 is a little unique as it was in an early Denali matted to a 4L60e trans. Unfortunetely the Z06 cam is NOT an option with this LQ4 as injectors & fuel tables were different in the early LQ4's compared to my 6.0/Z06 tune I developed for the later LQ4's. Because this was in a Denali in 2002 it is a DBW throttle body.
2004 6.0L LQ4, 104k miles - $3600.00 Turnkey + Options!
Another clean California based engine. This LQ4 was matted to a 4l80 transmission if you want to run the "big one". Otherwise the TH350/400 or Manual trans is an option. The Z06 cam is an option with this LQ4 and should put out around 375+ HP. It is DBW.
Here is a MONSTER HO LQ9 6.0L
2004 6.0L LQ9, 86k miles - $4200.00 Turnkey + Options!
This is the well sought after High Output 6.0L. With performance tune around 355-360HP. With the addition of the Z06 cam & springs should be right at 385HP. If you can run long tube equal length headers it may breach the 400HP mark optimally!
They are VERY clean and the cream of the crop. When completed they will look just like all my engines pictures posted.
Option List
4L60e/4L80e +$50, Cruise Control (DBW only) +$50
TH350, TH400, or Manual Transmission no charge.
See first post for shipping info, etc.
Production right now is about 3-4 weeks out to process these engines. $500 deposit secures as yours. Balance due 7 days after completion. Email direct or call to finalize. Will provide Carfax on EVERY engine and a tentative completion date with deposit.
1. Who is making the best "kits" out there? Meaning drop in motor mounts, crossmember, etc.
I'm not sure on "kits" but I used Tennesee diesel mounts with a custom crossmember I modified. I had a little bit of body interference on the top of the trans tunnel but IIRC you have a body lift so you would be fine. Scotts mounts land the engine nicely front to back and height wise
2. I realize I will need to do some frame work to the engine area to handle the monster torque. Is boxing the front horns of the frame pretty much keeping cracks at bay or is more work needed?
I boxed from the front to just past the front cab mounts
3. What is the spline count on my 700R4/241 and what is the spline count on the 618/205 combo? I assume, with the correct adapter, I wouldn't be able to just bolt on my 241 to the 618 without changing the output shaft?
IIRC all dodge auto stuff was 23spline and manual stuff was 29 spline. You 700 / 241 should be 27spline. Why not keep the Dodge 205?
4. I never wheel, so a D60 was never even really a thought, " why haul around the extra weight for nothing" I thought. I would actually like to keep my 10b up front, but can the bearings and ball joints last any decent mileage with the weight?
Like Shawn said, Maxpf did a nice swap and was running a 10 bolt up front.
Oh, and I'm actually considering the weight of the Cummins on the front end a good thing. I'm wanting my K5 shorter anyway, and if the front springs happened to sag 2 full inches, that might be just short enough to not have to make a suspension change. With those front springs loaded up, I'm sure it will ride much smoother.
granted mine is not anywhere near done, but the 12 valve really did not seem to squat my 6" springs much more then the BBC did when it lived there
Thanks for the info. I prefer a 241 over a 205, and I thought that if I got lucky I wouldn't have to do anything to my drivelines if I were able to reuse the 241 and it happened to stay in the same spot. Plus my 241 is rebuilt. No big deal, I'll just go with the 205.There are some pics of my boxing, the crossmember and how the engine sits in my K5 build thread.
Ummmm..... ewwww!Swap in an NV4500 and your left foot controls the lockup![]()
There are a few aftermarket stand alone controllers. I think I'll go that route. I want it to be automated and not have to run a pair of toggles during stop and go.There was a nice rig up I saw use Hobbs switched for the lockup and OD.
