Where are you reading pressure? Did you put a pressure gauge at the throttle body?
I might have to try one of those.
Would one handle a mild carbed engine if I decide to go that route? I liked the TBI I had on my 89 K2500, but after I did the TBI swap on the 79, it hasnt worked right since, and I'm getting sick of messing with it.
I really should get a pressure gauge on it. What gauge did you go with? CFM tech has the 0-15PSI, and a 0-60, Is there a range that would be more ideal?
so....... chevy305 was right....
I should have made my stabilizer mount adjustable...
Mutt is wearing the inside of my KM2's pretty bad, well noticable anyway... only about 4500 on em, and you can see the uneven wear... equal on ds and ps.... I have to assume I have too much toe-in... camber looks fine, king pins are all new, etc...
the truck drives beautiful, tracks great on the highway and such.. I'll have to see who locally has a drive over machine to check it... and I'll have to disconnect and redo the stabilizer mount once corrected... in the meantime, I'm going to rotate the tires to get an even wear pair from the back up to the front before the fronts get any more f*cked up..![]()
No regrets on welding the steering stabilizer bracket on the tie rod? Gonna have to give the thing a full turn to adjust toe now no?
