annoying life getting in the way of priorities...
I'm kinda chompin at the bit...![]()
gonna be a nutty Lab yr this year!![]()
actually, I've been working on the K5 a bit.. dash stuff.. Mutt is just in a planning/design stage... hopefully I'll have a pile of tube on the floor come april 1st...
I've actually already started tweaking the upper tube design... trying to give it a similar feel as the K5 has in the back... but the side toolbox 2 tube area is set.. taper in at the back...
come home, reverse...the only issue at this point is, exactly what i'll do with the taillights.. I actually considered doing a semi-full red lexan panel there.. do the panel in alum, than cut out a window in it, leaving an inch or so border, than the middle fitted with lexan, rubber windshield-like gasket around it..
