No one will ever expect that under the hood of that truck, that is for sure.
Martin
I just had to go back and read the first page again to remember what it looks like.
Martin
, dropped the tank and put in a new sending unit and the walbro 255lph pump, plumbed the regulator filter, and got the tank back in.
I see you bolted the tranny rigidly to the crossmember and then put bushings on the outside. I would add a bushing to the center where it bolts to the xmember because if the only bushings you have in it are wider and/or stiffer than the motor mounts you may break a tranny case. So unless your motor mounts are solid steel I would add a bushing between the tranny and crossmember.
The motor and the trans are mounted with the same bushings. They might as well be solid they're so tight. I did the bushings on the outside to make it so they would flex easier with the width of the crossmember adding force. I would think technically the trans should be softer because the fulcrum point on the bushings is wider no?
Its the other way around, the tranny has the same torque no matter what the distance, so if you move the bushings further away less force is applied to flex the bushings essentially making them more rigid. Using the same on both is OK, but I would only do that if the trans bushings are narrower than the engine bushings.
If it was mine I would take your center bracket welded to the tube, cut it off and flip it upside down and reweld it and then put one of these in there.
Or just put another bushing in between there. It might be just fine, but I don't think I would want to find out.
I'm glad you are getting the trans mount fixed, you will feel better when it's done. Sorry it caused extra work for you.
Thats a sweet cable. If they have you cut the cable how do they have you crimp the little ball or cylinder on the end of the cable that slides into the throttle pivot arm?
