So jealous of the amount of room you have to work with!!
Yeah its nice to not be jammed into a foxbody for once...So jealous of the amount of room you have to work with!!
The intercooler you want mount between the intake halves?
You should make a stencil to spray paint Frigidaire on the cooler...
Looks awesome, wish I had the equipment/ability to weld aluminum. That exhaust is going to sound rediculous, in a good way. I started mine the other day with the downpipe and a couple feet of 4" no muffler, may leave it that way.
Aluminum is a strange animal thats for sure. You basically throw out everything you think you know about Tig welding steel and start fresh. The arc doesnt distribute evenly when starting your weld, it jumps back and forth between the two pieces depending on torch angle and can make welding 2 different thickness materials together quite tricky at some times. Plus machine sizing is a huge factor for thicknesses. Welding something too thick or too big for the machine can be so daunting it just flat out doesnt work because the material just rips the heat away from the weld zone so fast.
Im by no means an aluminum expert. In fact my pie cut pieces came out pretty darn good but my tubing to intercooler pieces were fairly lackluster IMO. If you're interested in welding aluminum you cant beat an AHP Alpha 200. Its what I use and is about $650 off amazon.
Aluminum is a giant sponge for heat. Thicker pieces might need a little preheat. Nothing crazy just take the chill off of it.
Now if extra heat/penetration is needed you can use an Argon/heilum mix or even straight heilum. Just remember to turn up the gas flow rate. With heilum it'll burn in really good.
With inverter type tig welders sharpening the tungsten to a fine point helps also. Lanthanated tungsten works really good for steel, stainless and aluminum.
Lol I made that fan shroud for Ryan's lq4 jeep the other day and he says to me on the phone "yo don't lupino my new radiator pls"
lol. It was still usable though
. But it was one of the first aluminum projects I tried when I first got my tig welder.Whatcha got left before we get some test hit videos?
