"relevant, chronological order" ... I like that Idea, Wish I could change the thread name now lol
"you'll have less work getting the bracket worked out, than you would have retro-ing in tbi..."
I belive it used to be just that , TBI no? No less, if this is what well experienced Chevy guys would do, then this is my mission now.
SO! All that being tied together, I'm getting started!
1st AM , I'll be calling Wipple to see about there brackets. Till then, Ill do what I can.
First things first , lets remove the monstrosity of a air intake!
Done. Wander how much air it was really getting??
Made quick work of the PO's BS bracket and all the one bolt and small screw holding it in..
Questions..
#1 I'm pretty sure something needs to go here, like a PCV but its on the other side.
#2 This white wire which has a plug is disconnected. Is from the bigger grey looking plug. ( I didn't do it
#3 I'm thinking this is were the TC cable should ultimately be connected?
#4 Are these two bolts okay for a foundation? The rear most bolt was used with the PO's bracket.
Red line shows the TV, Blue the throttle cable. It need replacing, It was wound up like an extension cord and frayed, split etc.
The "other guys" bracket.. Look familiar? I'm saving it to trace for TV cable and Throttle holes.
So just to make sure I am understanding correctly, I BASICALLY need a bracket that sits square, parallel etc with in the specs by the links provided with what is now the linkage? Like what would be in it's stock configuration.?
For grins, this was my old rig, I sold it for this HeavyChevy!
I BUILT this truck Bumper to roof rack to font bumper to lift so on and so on.. I will do much more and better to this old rig. I had to move out of this cuz, well < I'm kinda a big guy... Not fat tho!
