The Beige Jimmy
That REALLY dresses it up. So much better than those bland black wheels.
How does it drive with 2.73's and 33" tires?
Martin
Martin
It's a lot noisier and a little more difficult to get started in 1st. I've been using L a lot more from a stop.
Should I keep the trim rings on or take them off?
I like the trim rings, but there were occasions when I would take them off rather than loose one offroad. I think that if you air down is when you may lose one. Just my opinion.
That's kind of what I'm thinking.
The rings add another element and dimension, but in a more sophisticated way. Without the rings looks more rugged and trail ready.
Yeah!
I haven't been able to install the new axles yet. Also I took off the trim rings because they were squeaky.
I bought a new set of rings from O-O-O-O'Reilly's, but I'm too weak or ignorant on how to install them. It's almost like the clips are arranged on too large of a diameter to fit.
Guys, this is so ignorant but for the life of me I can't figure out what people mean when they say "beauty rings" or "rings" on these wheels. I can google it and see pictures of them, but I can't see them in place on a wheel. Can anyone show an arrow or something for me? I feel like an idiot.
Got it looking proper with my refurbished rally wheels and a set of gently-used 33x12.5-15 Goodyears.
They're referring to the chrome trim rings at the outer perimeter of the wheel. The first quoted pic has them but the second does not.
Dang, I should take a picture of what the trim rings are. I bought a new set of a thinner thickness that really look sharp.
Since my last update, I moved across the country from Denver, Colo. to Portland, Ore. and had the Jimmy hauled on a trailer. It ran fine maybe the first day or 2 commuting to and from work, but the point is it has a miss now.
It sounds like I only have 7, maybe 6, cylinders firing under load, and it idles a smidge rougher as it did in Denver. Checked all the plug wire ends to make sure they were connected. No change.
Then I started swapping out plugs, when I noticed cylinders 6 and 8 were way different from the rest.
Here are the rest. #2 (or possibly #4) was also gunked up slightly.
All the odd numbered plugs looked dry and tan, like you'd hope.
So what's my issue? Stuck rings, burnt valve, shelled out motor?
Do I just need to take it on the highway to blow the cobs out and quit being a scared lil tree hugging hippie?
Is it too much fuel to one side? Like a dual plane intake and the carb isn't right on the side feeding the right bank?
And maybe some valve seals not perfect too?
