The Beige Jimmy
I know on a 6.2 it was wasier to get from the bottom of the truck, not sure how it would be on a gasser motor. at least your pump isn't in the tank like mine (n)
I did remove the air pump and bracket to access that hole. Fighting the pushrod is one thing, but the biggest pain was getting the fuel pump lever under the pushrod. Then getting it into position so the bolts would line up with the holes was seriously so difficult for me.
I watched a video that said once you get the lever slid in under the pushrod, to rotate the fuel pump slightly clockwise and just get the rear bolt started. Well let me tell you what, that is much easier said than done. I couldn't rotate it as far as I wanted because the round diaphragm housing hit the motor mount. I had to apply upward pressure to the pump (slightly compressing the very stiff lever) while aligning and pressing in on the swivel socket and 12" extension on my ratchet to get the bolt to bite into the threads because my left hand kept cramping up.
Pretty soon the 90 minute RTV was getting tacky, then it got slippery, and I was sweating like sweaty guy in a sweating contest.
I invented about 4 new curse words befofe I could coax that back bolt to get started. Then I rotated the pump, keeping pressure on the lever, and got the front bolt (the non-stock one that was on the Jimmy when I bought it) going a little easier.
On the 6.2 the space between the engine and the frame is tighter because the engine is a bit wider
Maybe that was part of my problem. I bumped the engine over a few times to find a better position on the cam but never found the sweet spot. I've heard having #1 cyl. at TDC is where you want it.
Old Chevies are supposed to leak, right?
I really don't like any leaks, but I'm considering leaving the fuel pump alone for the time being. Just developed this leak yesterday.
Finally got around to fabricating brackets and installing modern rear seats. I think they were 3rd row seats out of a GMC Tahoe or Suburban, 2004 or 7. Something around there.
Anyway, I got some 1/4" flat bar from Ace hardware. 3"x4' for the front mounts, 2"x4' for the rear mounts.
For the front brackets, I eyeballed that the 2 factory 1/2" bolts could hold it down nicely if they were centered front to back on the bars.
Then I folded the seats down and eyeballed that my rear bar lined up pretty nicely with the factory rear mounts, the recessed round bars in the floor. So I put 2x2" u-bolts in and by golly, it lines up pretty darn well.
I may go back later and sink a couple bolts on this rear bar through the floor and use some large fender washers underneath to hold it down more securely.
The mounts themselves came in a kit on ebay a few years ago. I'm sure they still sell them.
After I mocked them up and installed everything to make sure it'd work, I removed and painted the bars satin black. The reassrmbly was pretty straightforward.
I left the bars the full 48" width. I didn't see a need to cut them down at all.
Final result. The kids were not as enthusiastic about these seats as they were when I brought them home from the junkyard 3 or 4 years ago. They've grown to much prefer the factory bench and lap belts, but I like the increased safety of the shoulder belts these have. Plus they're in nicer condition than the factory bench.
From the rear, they flip forward nicely. The bracket sticks up out of the floor some, but I think it will be a minor issue and only rarely at that.
They fold this way too.
And upright. I haven't treated the stain, but I don't really care. They're junkyard seats and this isn't a show truck.
Cost breakdown:
Seats $50
Seat mounts from ebay $60
1/4" 3x48" steel flat bar $30
1/4" 2x48" steel flat bar $20
2- 3/16" 2x2" u-bolts $4
2- 1/3-13 2 1/2" bolts $4
Washers $1
Spray paint $5
Total: $125
