B
You wiped your table just so you could write that...
Damn straightin blue sharpie for the double win...
I keep trying different methods, but the tack-tack just comes out the best for me on the exhaust. Haven't had leaks or cracks or failure so I figure it works just fine.
Then I cut the pipe apart. On those, the sections I did with the “tack tack” method looked better both inside and outside the pipe. The was also true if the butt seem sections. The overlap sections looked better with the constant bead
Cutting the test pipe open was fun. That hot tack, although slow, will probably be heavily utilized.I found HOT tacks (overlapping) worked best for me when welding the butt joints on the exhaust. Otherwise penetration was weak.
That’s how your supposed to do it right?I found HOT tacks (overlapping) worked best for me when welding the butt joints on the exhaust. Otherwise penetration was weak.
Yeah thats how I do it for as long as I can without blowing holes through.I found HOT tacks (overlapping) worked best for me when welding the butt joints on the exhaust. Otherwise penetration was weak.
Tig it or gas it and lets be done. Mig is for muffler shops.![]()
Buy me a tig, I’ll use itNever TIGED, I have done a ton of welding with blue flame. I have 2 mig , 1 stick, blue flame and no tig.
