B
Bent77
Guest
Been in that case several times. I have to be missing something
I don't understand how a straight roller bearing would get pressure on it to walk out.Been in that case several times. I have to be missing something
Not going to tack weld the aluminum to the steel. TwiceTack weld it
I'm thinking the plate might need replaced. It's probably not putting that much pressure on it, it's just that loose. Mark hasn't said the strap is bent; I'm guessing there's that much play between the strap and retainer.I don't understand how a straight roller bearing would get pressure on it to walk out.
I wonder if the aluminum retainer plate is just a little loose when it warms up. Maybe some retaining compound would help along with the strap.
Otherwise, wouldn't the front output shaft have to be walking a lot to shove it out? If the front yoke was VERY loose, then maybe it could walk backwards, but I doubt that you would miss that.
Front is tight. But I have time to checkI don't understand how a straight roller bearing would get pressure on it to walk out.
Strap was hard against the retainerI'm thinking the plate might need replaced. It's probably not putting that much pressure on it, it's just that loose. Mark hasn't said the strap is bent; I'm guessing there's that much play between the strap and retainer.
Hey @Bent77, In that 205 book I got, it says that that plate and bearing are non servicable. To be replaced as a unit. I wonder why they say that. I just pressed in a new bearing like you did. So far mine is ok, but I don’t have as many miles on mine as you.
Nice of you to order that for me!I'll just leave this here.
The 5.0 is out of stock.Nice of you to order that for me!
Is ok. I has 6.55 1st gearThe 5.0 is out of stock.
Would be 133:1The 5.0 is out of stock.
