B
Bent77
Guest
Hard to see from a chairDoesn't look like work to me.
Why? they are welded solidNo tube sleeves?
Thought it was just the way it was done if you cut a tube to lengthen it.Why? they are welded solid
I do tend to overbuild stuff.
I wouldThought it was just the way it was done if you cut a tube to lengthen it.
What about shock mounting?roll cage sure.....
he’s probably planning on having legs on either side anyway.
it would make a great spot to mount one of those king offroad jacks, would be a lot safer then a hi lift.Im not mounting the shocks to the sliders
Send me one and I’ll seeit would make a great spot to mount one of those king offroad jacks, would be a lot safer then a hi lift.
And BTW, even with my square tube I've tweaked it. Drop anything hard enough and its going to move.That’s the @mrk5 door plan...Don't listen to all these naysayers. When the door doesn't open you just push harder and then trim more off the bottom of the door. Its like a self correcting problem which ends up giving you more clearance and removing any body rot. I mean its a win-win-win.And BTW, even with my square tube I've tweaked it. Drop anything hard enough and its going to move.
I agree if I make a mistake and haft to lengthen tube I always put a sleeve on the inside if it’s ever gonna crack or break it’ll be at that weld imo.Thought it was just the way it was done if you cut a tube to lengthen it.
