Mooshed the factory throttle cable bracket over 180* to level the cable mount point to the TBI. Painted it "not black" after welding a reinforcement plate to the back
Thanks @Blue85
Looking for a longer speedo cable
He posted up this info:
found 2 standard lengths available these days:
100" - ACDELCO 88959481
80" - ACDELCO 88959478
There are aftermarket versions priced pretty reasonably.
Which led to this...
Finally got in a test drive. Speedo is Waaaaayyyyy off.
Throttle cable is much better. Also now makes my second favorite sound again: that crap ton of air going in the intake, a glorious noise I haven't heard since Qjet secondaries
I figured out how much mine was off and ordered the closest gear ratio box thingy that attaches to the T case and now its pretty good. Between the tires and change to the doubler it was out by quite a bit. Now its within reason.
You going to make it this year?
