It's fubar.
Ya think?
:dunno:
It didn’t fall out
My axle building buddy thinks my clanging is the gear oil needing anti-spanky. Everything locked in feels pretty tight.
Pulled the axle apart anyway (been a couple years) and didn’t find anything out of line, oil looked fine. Might do shaft joints although they don’t give any indication of issues
Ya think?
:dunno:
It didn’t fall out
Pulled the axle apart anyway been a couple years) and didn’t find anything out of line, oil looked fine. Might do shaft joints although they don’t give any indication of issues
Sounds valid. I'd go with a fresh TRE as a just in case precaution. I don't know that I'd go after the joints unless they felt like they were stiff or hung up at all.
Yeah I have a new tie rod. Need to melt the assist mount to it. Guy gave it to me at the cruise last month because it wouldn’t fit his. Thought that was pretty cool
This tie rod was replaced in 1997 at 75k. Guess it served its time
That's pretty cool how you got it. If you've been driving the truck and wheeling it since 97, 20 years is a good service life. Better than tie rod ends, idler and pitman arm joints wiping out on lifted IFS trucks with under 50k in miles on them.
The tie rod end should be inspected under load. Put it back in and have someone turn the wheels left to right in quick 2-3 hour increments on the steering wheel. Be sure to hold the brake while doing that and the truck running.
Then watch each joint and look for play that way. A tie rod end will move in its socket but that video didn't show much. You had to force it to move so I'm not betting on it being bad just from that.
Yeah I checked it before teardown. It makes Cheeto noises
And only about the force of a Cheeto to move that. Definitely needs replaced
Resolution to high pressure pumping without leaks. Thanks @ZooMad75
P.S. Earls fittings did not come with o rings
@max 02
The saddle tank sender will go in the 31 tank. It’s about and inch shorter than the TBI sender though. But if you’re not using an intank pump, it would be ok
@max 02
Looks like it should work. Most importantly it don't look like it will leak at all.
@max 02
Sweet! Thanks Mark!
I was mostly worried about the fittings not getting messed up. I was going to put another box around it full of packing material, but I just got lazy.
To do list
Somsome clunks removed, still something up there.
Went through the front axle and changed the drag link
Squeaky squeal thing under the hood
The A/F mixer needs some fine tuning. Runs okay but is too rich
Want to check the advance curve and total timing again
Handle throttle needs adjustment
Have 500 miles on the new engine already, so it’s due for the first oil change
